PIK20 (another one)
mjcp
PIK20 (another one)
Post by mjcp »
My (somewhat tatty) PT PIK20 suffered a jammed spoiler over the summer, so I have been refurbing the wing. The original covering appears to be 40 year old gloss house paint, direct to the wood skin... It was yellowed and lacking in shine anyway, then I had to go hunting for the Bowden to see where the jam was.
Turns out it was a break in the spoiler mechanism, not the Bowden, but surgery was required either way. Here's a few pics of the process.
Playing "hunt the Bowden" - It isn't under the wing :-(
Ah, here it is, on the top of the wing...
Spoiler removed and disassembled, ready to rebuild. I suspected the Bowden had detached or broken, but it was actually he clevis (old and plastic).
A new metal one was soldered to the cable and the spoiler removed for a refit - its nice and tight (as in free of play, rather than full of friction!), ready for another 20 years of action.
Lower damage caused playing "hunt the Bowden" refilled with foam, ready to be reskinned.
Original covering has the appearance of old gloss paint!
100g of covering removed.
Replacing the glass reinforcement at the root - well wetted glass
..and "dried" via the "Kitchen paper" method...
Top surface glassed
The spoilers have since been freed from their glassing and retract to a nice smooth surface.
Next steps will be to lightly smooth and then spray fill, knock back / 2 pack top coat / seal etc.
Then I guess I should do the other wing!
m̶j̶c̶p̶ Marc
Hanger -
Graupner (old) K-8b, Mini Solius chuck glider conversion, UMX ASK-21, HF/Czech 2m ASW27, DG808s 4m, X-models Mini-blade, Lidl glider pitcheron.
terry white
Re: PIK20 (another one)
Post by terry white »
Nice one Mark, I loved My Pic 20 from Pat some many years ago now ,certainly worth you giving it another lease of life.
I remember travelling down to Weston Super mare to pick it up from Pat just before Christmas, then giving it to my wife who wrapped it up and put it under the tree as my present. Oh how young we were then. :roll:
Jolly Roger
Post by Jolly Roger »
Great repair Marc! It's a lovely feeling when an old airframe gets a new lease of life.
For inspiration, here are some photos of a Pik 20 that soared above our house last Summer.
mjcp
Post by mjcp »
The garage is a bit cool at the moment, so the office will work as a warm flat place to cure the epoxy. (Once its 24hrs+ it goes into the airing cupboard, vertically for another day or two to "fully" cure ready for sanding)
Rubbed down and then a coat of spray filler in the make shift spray booth.
Some more rubbing, followed by another base/filler coat and more rubbing. Contrasting colours of base/filler are handy for showing highs/lows and gauging depth of sanding.
Not sure I'll go to the extremes of smoothing over the spar (dark grey area) but the control surfaces will be very smooth!
m̶j̶c̶p̶ Marc
Hanger -
