Page 1 of 2
Washout included in Flight mode trim?
Posted: 19 Mar 2017, 08:19
by Phill Tadman
Hi all,
I'm trying to set the flight mode trim on my Baudis Antares but am not sure whether to correct for what I believe is washout in the wing towards the tips.
If for example a recommended thermal setting is 3mm down on the entire wing, setting 3mm at the wing root and keeping the surfaces aligned results in about 1mm at the tip.
Is this is how it is meant to be or should I have steps between the flaps, inner ailerons and outer ailerons to achieve 3mm down at the tips?
Thanks,
Phill
Re: Washout included in Flight mode trim?
Posted: 19 Mar 2017, 18:23
by jimbo
I usually set the inner flap to 3mm and align it as you suggest. Interesting point about it not being 3mm at the aileron end, never really thought about it until now, I'm pretty sure my thermal mode is less droop at the aileron too on both my alpina and big asw20.
I may try setting 3mm through out and see what happens. Suffice to say thermal model is effective as I fly with how you have it set up at the mo.
Posted: 19 Mar 2017, 18:27
by Ian Stromberg
A thermal flap setting of 3 mm down usually means 3 mm down measured at the wing root and the surfaces are kept aligned across the wing. 3 mm down at the tip would give considerable washin due to the much reduced aileron chord at the tip.
Posted: 19 Mar 2017, 20:24
by Phill Tadman
Thanks for your input gents.
Thinking about it, with the surfaces aligned, washout (leading edge down, trailing edge up) at the wing tip should result in a bigger aileron droop not smaller.
Does that mean the wing has washin?
Perhaps tip stall is reduced by having winglets?
Phill
Posted: 19 Mar 2017, 21:27
Phil, as Ian mentioned, it all depends on the chord. If you continued your 3mm all the way to the tip you would have effectively aerodynamic wash-in. Not so much of a problem in straight and level flight but potentially lethal in thermal turns or low level manoeuvres. I learned this painfully a long time ago with glass thermal soarers.
With my flappy models like the 5 metre Alpina and ASW20 the flap setting starts out at about 3 or 4 degrees at the root and is reduced to 1 or 0.5 degrees at the very tip. This gives essentially a slight aerodynamic washout at the tip.
However when you come to set up your distance or speed trim you will find that having the whole flap/aileron set to exactly the same angle of reflex along the trailing edge (say 2 degrees) will give you the best results.
Posted: 20 Mar 2017, 13:35
by terry white
Phill, You have one super model there, I am quite envious.
Please be very wary of adding washout to a wing that has such a tapered plan form. An inspection of the aerofoil at the tip would show the aileron width to be a wider percentage when compared to the rest of the wing section.. This along with other alterations is the modification that the manufacturers speak of in their blurb.. If they used the true width of aileron it would be too narrow to produce lift when required in the roll axis. Only creating drag which is the last thing you want when requiring lift. Bauldis has used the F3B favored section P DIRK Mod. on this model, An excellent section which for general use does not need any alteration to perform at its Maximum efficiency. By altering any section with flappy bits on the trailing edge, you spoil the section not enhance it thus altering its designed parameters. I would advise only to consider altering the section by positive or negative flap when the drag it creates is also a bonus such as on landing approach or in minimum thermal .
The modern sections for glass ships which have been designed and tested in wind tunnels and further tested by professional flyers are already at their best.t
Also a properly designed wing incorporating built in washout will be built with a twist to the wing with the wing tip angle of attack being less then the roots. When the aircraft is in a position of stall the inner part of the wing will stall first allowing the aircraft to nod to regain speed instead of dropping a wing should the tip stall first, then enter a spin. If washout is programmed in at the transmitter on ailerons it is quite feasible that one of the ailerons will be at reflex ( say on the last leg before finals) this will create drag to that one aileron and possibly do the reverse of you good intentions.
The down side to this is that when one pushes the aircraft at high speed (which the Bauldis Antares is more then capable of) the root angle of attack could now easily be at zero - the wing tips angle will now have a high negative angle of attack. The effect of this is the tip trying to twist the wing, the wing appearing to the onlooker to bounce as the whole wing hunts from positive and negative angles. The long slender wings of the modern glass ship can often be seen doing just that. Although Bauldis say they have designed this problem out with 'special' carbon full length spars.
A number of manufacturers favor (as I did) a change of section throughout the wing, with the tip using a section giving more lift at slower speeds and can sustain higher angles of attack. This way there is no drag created at the trailing edge, no attempt at wing twisting, no wing bounce in hunting.
So Phill , A very controversial subject I know, but for my two penneth,leave your wing exactly as manufactured, only spoiling the section on finals, and as altering the narrow trailing edge of the wing cant possibly give you real washout only drag.. forget it.
I wish you well with your maiden flight and hope to see you and it at M.W. Regards Terry.
Posted: 21 Mar 2017, 13:12
by Antonia
Hi Gents,
For my four penny worth I copy the full size control movements with the exception of the thermal mode on the advice of John Greenfield, where I don't have the ailerons droop at the same rate as the flaps, this would give in effect a washout in thermal mode, this does work quite well, if pushed the ASH 25 will drop a tip, which can be interesting if you are flying some distance from yourself!...
With regard to the landing phase of the flight again I copy from the full size in the case of the ASH, the inner flaps go down to about 38 degrees and the flaperon function is removed, the outer flaps goes down to about 25 degrees and has approx 30-40% of the flaperon function, the ailerons go up by approx 5-7 degrees.
The flaperon function retains the 100:50 deferential ratio in cruise and thermal modes, in the speed mode the flaperon movement is reduced to approx. 70:50 deferential and movement of the ailerons element reduced by 50% as retaining full movement at speed could be interesting to say the least
Here's couple shots of the ASH's landing phase, the glider reacts a'la full size, very nose down attitude with no speed build up, very odd in a full size glider where the nose drop would accelerate you up to VNE in no time,... quite surreal!...
Antonia
Posted: 21 Mar 2017, 17:02
by Phill Tadman
Wow, thank you all for your input, this is all really useful stuff!
I think I'll keep the control surfaces aligned so that thermal flight mode trim set at the wing root reduces towards the tips as a function of the wing design.
I wont apply trim to add washout or washin to the wing.
I might add a touch of up aileron and down elevator for the landing mode which has 30mm of down flap and neutral flaperons.
Phill
Posted: 27 Mar 2017, 16:00
by John Vella
Phil, I agree with having the wing trailing edge move together over small changes of angle in the range of thermic , cruise and speed.You are spot on with the "crow" landing settings you describe.
However I was helping rig a full size ASH 31mi last Friday (similar size and planform to your Antares) when I noticed that the flaps and ailerons split slightly (a couple of degrees) in thermal settings. This must be done to give more wash out for better handling at low speeds. So this might be worth trying on your Antares?
Regards John.
Posted: 12 Apr 2017, 21:22
by Jilles
For what it is worth some info about the earlier Schleicher gliders, I have flown myself all Schleicher glider types from K4 up to ASW15B. (motor gliders excluded)
All had the feature that when you pull the stick backwards both ailerons went up by a few degrees, creating more (artificial) washout at lower speeds.
It did not involve complicated mechanical connections, it was just the result of how the ailerons were driven by the various push rods.
If you stalled the gliders there was no wing drop and still control on the ailerons. If you wanted to spin you had to push the ailerons to full left or right
and then the gliders were still reluctant to stay in the spin.
I plan to program the RX for my 1:3 ASW15B the same way and see what the result will be.
