airbrush recommendation
mick a
Post by mick a »
hi gents
has anyone got an airbrush recommendation , or should i use rattle cans as i have done before ?
SP250
Re: airbrush recommendation
Post by SP250 »
Mick
The answer is "it depends"
If you want large area coverage then cans or a touch-up gun.
If you want fine detail then an airbrush is a good investment - I have found these people very good https://airbrushes.com/index.php
Regards John M
FrankS
Post by FrankS »
I'll second what John has said, an airbrush is fine for details but no good for general coverage and the touch up guns you can get from just about any automotive paint supplier are perfect for that.
mick a
Post by mick a »
thanks gents
never too good at spraying , normally use rattle cans , just wanted to try to improve will look at touch up guns , i have a small airbrush compressor, will this work with it ?
