wood covering
mick a
wood covering
Post by mick a »
hi gents
wonder if you can help me, i saw on cliffs pictures of his visit to the museum
there was a mo2a , but natural wood finish
i was thinking of doing this finish on mine (only a thought)
has anyone any advice on how to do this ?
i.e what thickness to use ( was thinking 0.8 ply )
patterns etc
here is cliffs pic and where i’m up to at moment
thanks in advance
Martin Gough
Re: wood covering
Post by Martin Gough »
Hi
Im ply covering a Reiher build and Im using 0.4mm ply.
Works well using the wood glue letting it dry technique
and then ironing the ply to the frame.
Martin.
mick a
Re: wood covering
Post by mick a »
thanks martin
looking good , i’ve already covered the frame in ply, so it would be on top of that.
not sure if it would be too much weight
Jilles
Re: wood covering
Post by Jilles »
if you have already ply on the fuse no need to put an other ply layer on top
It does not matter if you apply 0.4, 0.6 0,8 mm ply as long as it is ply.
The trick is to get nice overlaps at ply panel joints. It is also helpful to prevent any any glue to come in contact with the outer ply surface because they will show up later when finishing. I used wood stain before varnishing to get the what darker color
Attached some pictures on my Fokker baby and the Dutch version of the Early primary glider ESG
Both have stained and varnished surfaces. You will note that despite the wood stain you see differences in color between ply sections
This is completely at scale because the prototype had this feature as well.
mick a
Re: wood covering
Post by mick a »
thanks jilles
the panels on the minimoa are small individual , that’s why i was going to put more over the top of what i have
like this
Re: wood covering
Here are the old Docs awaiting to be added to the website
SSUK - Minimoa Mo 2a documentation.pdf
(4.03 MiB) Downloaded 78 times
mick a
Re: wood covering
Post by mick a »
thanks vince
great help
