Scarf joint question
harry curzon
Post by harry curzon »
I am about to make the wing spars for the Charlesworth K-18, 4 metre. I need to scarf join the spruce spars, what is the recommended length of the joint? 5 x width? More?
john greenfield
Re: Scarf joint question
Post by john greenfield »
Harry
A structural scarf joint should be 15 x the thickness of the pieces being joined.
harry curzon
Thanks John,
the spars are 10mm wide x 3 mm thick, so the joint should be 15 x 3?
.................and Harry, make sure they are perfect. Check both down their length and across the width with your straight edge and clamp really tight.
John Vella
Post by John Vella »
Harry , what glue are you using on such a critical joint ?
john greenfield
harry curzon wrote:
23 May 2019, 09:16
Thanks John,
Yes Harry. 45mm.
harry curzon
Thanks John
This information from the old site
John Vella
Vince, the splice angle recommended from the table is 15 to 1 for ply and 20 to 1 for wood. This is what we were working on with K13s and K8s. What I can't understand is the diagram below ? Surely the joint is stronger in bending load than shear load ? Regards John.
What about the scaling factor...? Surely, a 1/4 scale spar would only need 1/4 of those dimensions? 8-) :lol: :lol:
