Epoxy
Re: Epoxy
Post by RobbieB » 02 Jul 2019, 23:05
B Sharp wrote:
02 Jul 2019, 18:59
Robbie, I used epoxy rather than polyester for the canopy mould for my BG135. I also used cloth rather than mat thinking I was being smart. BAD MOVE!
When heated during the pulling process the epoxy shrunk and left me with a pronounced weave pattern on the finished canopy. Barry at Sarik put me right!
Brian, are you saying both the epoxy AND the cloth is a bad idea as I was intending to use cloth?
Once glassed (two layers) I do intend finishing with P38 or similar.
Re: Epoxy
Post by B Sharp » 03 Jul 2019, 08:22
Robbie, I used 3 layers of heavy weave cloth applied with laminating resin. The cloth was then rubbed back to as smooth as possible. A further coat of resin was applied and rubbed back. I suspect that if I had used mat I would have got the same result but with an imprint of the mat.
I have returned to using a blue foam core on 1/4 ply base, covered in parcel tape then fiberglass mat and polyester resin. After sanding with 60 grit it gets a coat of P38, sanded and polished to a finish.
Re: Epoxy
Post by Cliff Evans » 03 Jul 2019, 08:41
P38 will react to the heat, how it reacts varies. Cracks, bubbles or just weakens and sticks to the plastic. I have wasted so much time and effort over the years. There is no easy answer.
Re: Epoxy
Post by RobbieB » 03 Jul 2019, 17:15
B Sharp wrote:
03 Jul 2019, 08:22
Exactly as I've done in the past Brian (only two layers of matting used) and it has produced almost perfect results albeit on easy canopies to pull:
I was just trying to avoid using polyester and mat - not nice to handle but the heating/softening of epoxy does make sense - classic method to extract a metal component from an epoxy enclosure.
MDev
Re: Epoxy
Post by MDev » 03 Jul 2019, 17:29
Use a marine epoxy white undercoat and add pigment to it at 6percent, polishing each successive layer with wet and dry with a higher grade each time. You’ll get a much better finish. Or easy sand particulates with pigment added.
