Well, having done some digging around it seems Eze-Kote might be the answer: https://deluxematerials.co.uk/products/eze-kote
Not temperature critical, fast drying and no mixing it has non of the disadvantages of the other systems and it's deliverable behind the iron curtain
Sounds ideal, any experience?
Glass cloth application
Re: Glass cloth application
It is easy to use and easy to clean up after. ExeKote is nowhere as hard as a resin finish and takes many coats to fill the weave. However, hi-build primer will quickly fill the weave and give you a smooth paint base.
Rgds
Mike
Rgds
Mike
