Uk for parts ?
Uk for parts ?
Hi all, are we still buying gliders and parts from abroad or has a uk supplier appeared in the last couple of years . Just looking for a sliding window for my 1/4 scale and it seems shopping abroad seems the only options unless someone could offer some advice on uk shops.
Thanks rob
Thanks rob
Re: Uk for parts ?
Rob, try Gliders Distribution...
Re: Uk for parts ?
I can 3d print some slides, the window would have to be cut out from petG or similar.
Re: Uk for parts ?
What thickness is needed for the sliding part? I have a roll of .5mm I use for servo covers I could use.
M
M
Re: Uk for parts ?
I would say 1mm would be best!
Re: Uk for parts ?
Great idea on the 3D print, my local model shop can help with that thank you, they made some plastic pins for me for my air brakes.
Re: Uk for parts ?
Hmm I already have them drawn up ready to print. I do wonder sometimes why I bother.
Re: Uk for parts ?
Hi cliff that would be great could you make me some up then please thanks rob
Re: Uk for parts ?
How do you make the spring that pushes the window outwards into the hole?
Re: Uk for parts ?
Pm me your address.
