engineering question
Elliot Howells
Post by Elliot Howells »
Quick question, I need to drill out a deep wall socket slightly so that it engages with the hex on the DLE111 prop driver, I've managed to dill a few mm, but it's so hard, the drill won't go any further - any suggestions? I only need another 3mm depth.
TIA, Ell.
Keith
Re: engineering question
Post by Keith »
Hi Ell, u need a cobolt drill! What size as i have some and younare welcome to what you need.
Keith
Elliot Howells
Keith, that's really kind, I need a 10mm, never needed anything but HSS before...
Ell :)
Keith
Post by Keith »
Ill check in the morning, but i dont think i have 10 mm.
Chris Bowles
Post by Chris Bowles »
Hi Elliot, when we had to drill broken studs, that had hardened, we found masonary drills worked very well, slow speed, oil and quite a bit of pressure on the drill, you don't get an exact size hole, but it might suit your needs
best of luck Chris
You can get them here I think:-
https://www.ukdrills.com/
Keith
Post by Keith »
Hi Ell sorry the largest i have is 5 mm.
Keith
