Images
Images
All images uploaded from now on will automatically have a scale soaring watermark place on the bottom right-hand corner. Pictures are being used from the forum on other sites and giving us no credit which I believe is not right. Please see sample below.
- terry white
Re: Images
brilliant
Re: Images
Well done Cliff
Re: Images
Good idea Cliff. Keep up the good work.
- mjcp
Re: Images
(but on a serious note)
Can you configure the watermark text to be black outline / white text or vice versa? That way, its visible no matter the background:
m̶j̶c̶p̶ Marc
Hanger -
Hanger -
Re: Images
That should do it...
Re: Images
I went through this with my own website a while back, my son is a graphic designer and sorted it out. If you place the wording mid picture but make it less obvious so it looks like a watermark then pictures aren’t copied and altered.
M
M
Re: Images
Good point.
The picture above can so easily be cropped to exclude the watermark without restricting the content significantly.
