Fitting incidence tubes in wing
Re: Fitting incidence tubes in wing
Yes, all you have to do is notch the cap strips for the front of the gussets so that they are flush, and overlap the TE to about half the width of the balsa lamination, then feather the ply out to a minimum thickness... This Flamingo rudder will give you the idea.
Thanks for the reply Chris.
