Down and side thrust
Posted: 14 Sep 2020, 22:25
I have acquired a second hand Tangent Nimbus 4 to which I am fitting an electric motor in the nose. Can anyone give me guidance as to a sensible amount of down and side thrust that would help it, or is none required? Some friends build in as much as 7 degrees of down thrust to their scale gliders.
The model is 6m span, weighs around 9.8kg, power is 8S pushing about 2.5kW through a 16x8 prop, 400kv Hacker motor at around 9800rpm.
