Schempp Hirths very first ever glider series, the Gö 1 Wolf, will again take to the skies on Friday 24th July following a full restoration of a glider brought back from South Africa.You can read about the restoration here:
https://translate.google.com/translate? ... edit-text=
The glider was sold in America and Japan and was demonstrated by Wolf Hirth himself. Here are photos of him in Japan, does the wing remind you of anything?
Finally, here is an excellent 3-view if you want to build a model
The Wolf flies again
- VinceC
- Site Admin
Re: The Wolf flies again
Hi Vince,
what great news that an original Wolf will fly again.
Nice drawings too.
The Wolf had the outer wing and ailerons modified to address spin issues I believe - perhaps you can confirm that the drawing shows the glider as modified. I think the modification was quite time consuming and expensive and that many Wolfs were grounded and never modified (is that correct ?).
My impression is that like the Grunau Baby, the shape of the nose varied somewhat, although I would hesitate to say what was the typical shape. Photos of the Wolf do not seem very common so this also makes comment about the nose difficult.
Paul
Nice drawings too.
Paul
- Noël Rumers
...It was taken up too...
I have seen it last Saturday and didn't know that is was liked so much...
Just on picture taken...
Noël
Noël
Hallo,VinceC wrote:Schempp Hirths very first ever glider series, the Gö 1 Wolf, will again take to the skies on Friday 24th July following a full restoration of a glider brought back from South Africa.You can read about the restoration here:
die schöne Zeichnung ist von Rainer Niedree und wurde in der FMT veröffentlicht.
Ich habe den Wolf 1988 gezeichnet, hier ein Blatt meiner Wolf Zeichnung.
Findet sich auch in der Flugzeugtypenbroschüre Band 1
https://shop.modellsport.de/de/buecher1 ... -k-h-kens1
Zeichnung © by H.-J.Fischer 1988
Gruß
Hans-Jürgen
Editor:
Hello There,
the beautiful drawing of Rainer Niedree and was published in the FMT.
I saw the wolf drawn in 1988, here a sheet of my Wolf drawing.
Can also be found in the type of aircraft brochure Band 1
https://shop.modellsport.de/de/buecher1 ... -KH-kens1
Drawing © by H.-J.Fischer 1988
greeting
Hans-Jürgen
- VinceC
- Site Admin
Thank you Hans-Jurgen for your extra detailed drawing. I also have your excellent drawing of the wing
