Hello again
After receiving such brilliant advice on glider guiders regarding my LS3 tail, I now have another question. The elevator was pencil marked in the tailplane, but sadly there is no indication with regard to aileron.
My fist guess on position and width is as per the green tape. I have placed the tailplane in the photo as reference
Proposed aileron is 1000 x 25mm - for reference the elevator is 650 x 30 - the wing is 2m
Any ideas would be most appreciated
Cain
LS3 Ailerons
Re: LS3 Ailerons
Ps the servo cut outs are for aileron and airbrake - there will be no flap
Re: LS3 Ailerons
Hi, the LS3 had full span flaperons. The LS3A had flaps and ailerons split at the half span Mark. The chord of the ailerons is 20% of wing chord. I am sure the model will fly fine without flaps if that is what you want. Regards John.
