Some pictures of my scale 1:3 Crow motor glider. It is a German design from the 1950-60s. I started this built 3 years ago, but lost interest. After my ASW15 and Nimbus build, it was take up again. Wing span is 4 meter. Pusher prop of 15X10 driven by a scorpion S-4045-10 brushless on 5S lipo's
thrust is 3.8 kg (70Amp) or 4.3 kg (90Amp) with a 16x10 prop. Estimated flying weight 10 kg so not too much power but still 160w/kg so it should work
Just decided to fit a tow release so there is then an option.
Crow (Kraeha) motor glider
