is-5 Kaczka 1/2
is-5 Kaczka 1/2
Hello there is video of my new glider.
there i link for fhotos:
https://kesalokim.rajce.idnes.cz/IS-5_K ... alf_scale/
Petr
Petr
Re: is-5 Kaczka 1/2
Lovely, Petr, well done...!
Re: is-5 Kaczka 1/2
Very nice, puts our 1/3rd scale one to shame. Can you give some details, i.e. Wing sections used, c of g position and decalage. Ours is very "squirrely" if towed too fast and while flying OK the elevator doesn't allow a really good flare out.
- Philkiteflyer
Re: is-5 Kaczka 1/2
Loverly glider, nice to see working brakes too. However this might sound strange, can you give some details on the 'V tail" tug please?kaczka wrote: ↑25 Mar 2020, 11:58 Hello there is video of my new glider.
Petr
I am in the process of building a tug and I've always thought a "V tail" the most sensible way to go.
Thanks
Phillip C
"Keep it simple stupid"
- VinceC
- Site Admin
Re: is-5 Kaczka 1/2
Congratulations on a lovely model and video. Nice to hear the silence of glider flight after the tug lands. Are elevator movements very sensitive?
Re: is-5 Kaczka 1/2
Hello,
wing span: 6 m
weight: 20 kg
Wing airfoil: clark Y
cg position 75 mm befor leading edge
Flying habits are excelent. It is my second Kaczka. First is in 1/3 scale. It was dificult to learn it fly. But now is realy perfect.
Small Kaczka can fly acrobatic figures.
wing span: 6 m
weight: 20 kg
Re: is-5 Kaczka 1/2
Towing is called Bivoj (name comming from czech mitology)
designer is my friend Ivo Mikac. He was inspirated of Patchwor tug.
It is posible to buy the kit.
https://obchod.lasermodely.cz/motorove/9-bivoj.html
engine: zdz 160
weight: 16 kg
engine: zdz 160
weight: 16 kg
- SedB
Re: is-5 Kaczka 1/2
Awesome glider Petr!!
I assume your daughter (I guess) is only in the plane for the static shots!?
Daniel
Daniel
- Philkiteflyer
Re: is-5 Kaczka 1/2
Thanks for info on the tug.kaczka wrote: ↑03 Apr 2020, 13:54 Towing is called Bivoj (name comming from czech mitology)
engine: zdz 160
weight: 16 kg
A solid looking model, though a bit bigger than I'm looking for. I might try the V-tail though on my model.
Thanks and well done on your IS-5.
Phillip C
New Zealand
