CoG for a Valenta Salto
Anyone else fly the Valenta Salto and can suggest a good starting point for the CoG? Might even get a fly this year!
M
M
Re: CoG for a Valenta Salto
My friend has recently bought and been flying a Valenta Salto , he has experimented with the cg position and I will ask him to reply to your post ,
but his version is fitted with a nose mounted brushless motor , regards Ian Turney-White
I have the electrified version mentioned by IT-W.
I bought my Salto (4.5m version without winglets) second hand from a very experienced flyer who had set the c of g at 89mm. I have experimented with the balance and ended up back where he had it. The previous owner only ever sloped it. I have only flown it from flat field, so it would suggest that this is a good all round position.
He did warn me what it could be like if not correctly balanced or mishandled!! Don’t use too much elevator at low speed.
PP
PP
Plans call for 93mm from L/E. Mine is set at 88mm and it flies well.
- terry white
Mines 85mm no vices unless you slow it down too much. As has already been said before do so at your peril they bite hard.
With a v tail the two elevators coming up together makes for a good air brake at the back end. too much elevator will induce a flick, especially at the top of a loop..
Thanks chaps, I tend to take manufacturers figures with two large handfuls of salt, having been caught out more than once. If two people on here trust their gliders to these figures then that’s a good start?
Long may the forum reign.
Ta.
M
Ta.
M
As a post script:
Don’t be tempted to go too far forward, as you will need lots of up elevator trim to fly level, and then you are only a twitch away from a nasty flick and a three turn spin!
Flown fast they are great.
Terry and others
As a supplementary to the C of G question, what size servos are you planning to install, or have you installed, in your Salto?
I have seen installations with Hitec 125s, 4.8v, through to 2S LiPo systems with 11kg servos.
Mike
Mike
Mike, you could check out my Salto build log, which answers all those questions...
https://www.rcgroups.com/forums/showthr ... alto-H-101
Richard
PS The Salto needs to be flown fast or it'll bite. I'd steer clear of low torque / LV servos.
Richard
