WHO'S BUILDING WHAT FOR 2021
Re: WHO'S BUILDING WHAT FOR 2021
Next up: Sperber Junior...Scaled to 1:4.5, this should turn out the same size as the 5th scale Petrel and Flamingo
- Olli
My Rhöngeist Pofessor
goes finish
Best regards Olli
goes finish
Best regards Olli
Nice model Olli.
Motley's version of the 1/4 scale Minimoa from the forum nears completion...
- Ian Davis
Hi Chris
Here's the historic picture you really need, if you haven't already got it.
Many thanks, Ian...
The mini Bergfalke had its maiden flight at CMFC yesterday...
Specs:
Scale 1:4.7
Span: 3.7
Weight: 9lbs-(ish)
Specs:
Scale 1:4.7
Span: 3.7
Weight: 9lbs-(ish)
Very nice model, did it handle as well as you hoped it would?
A bit of a handful initially, due to a slightly rearward cg and too much elevator movement. Once these issued were sorted, she seems pretty much like the larger versions...
Thanks for your reply Chris. Out of curiosity how do you store the many models you’ve built? I guess it must need to be an aircraft hanger!
