SZD - 36 Cobra 15 1:3 scale
skyhawk92
Post by skyhawk92 »
Holes cut out, spacers inserted and aileron set in place.
skyhawk92
Post by skyhawk92 »
On the wing side, I glued spacers.
skyhawk92
Post by skyhawk92 »
... and reinforced them with epoxy and cotton fibers.
skyhawk92
Post by skyhawk92 »
With such an aileron, model response is very good.
skyhawk92
Post by skyhawk92 »
Both wings put together, so I can see how they fit.
skyhawk92
Post by skyhawk92 »
Covers for servo and "maintenance" holes...
On a place where the cover will be I made a sketch.
skyhawk92
Post by skyhawk92 »
I made a cut 1mm wider than sketch, and a bit more on the corners.
skyhawk92
Post by skyhawk92 »
Frame on which the cover will be fixed is made of samba wood from Africa.
skyhawk92
Post by skyhawk92 »
On the edge of the cover I drilled some holes, a bit smaler than the screw will be. I temporarily taped it in place and drilled holes in the frame too.
skyhawk92
Post by skyhawk92 »
I enlarged holes on the cover and screwed it in place to see how it fits. The gap that remains will be filled later, when other covers are made.
