And no it is not my own design, the vacuum machine. I have seen a smaller version in a model shop once.
At that time, my 1/2 scaled Moni had a very big canopy and much bigger than the 600 mm machine in the shop. So I was able to look into this machine and redesigned it and had it made a bit bigger as a school project that I sponsored...
A local company wanted to charge me a lot of money to pull a plug for me...
Now I have my own 950x550 mm big and in height about +220 mm.
More building on the Milan now...
The rudder was build up like Cliff Charlesworth did, with a pin and a plywood tongue. One screw will hold the rudder in place, easy in transport.
And know that the real rudder could be taken off as well.
The rudder control arm is made and also the tail wheel control arm. I used epoxy plate for this. These will be glued in after covering with fabric.
Noël
