SZD - 36 Cobra 15 1:3 scale
skyhawk92
Post by skyhawk92 »
Custom made template, before cutting of the canopy.
skyhawk92
Post by skyhawk92 »
Canopy, that will be later used as a mold.
skyhawk92
Post by skyhawk92 »
Template for wing placement.
skyhawk92
Post by skyhawk92 »
First rib, which will be later glued to the fuselage is taped to the wing.
skyhawk92
Post by skyhawk92 »
Wings aligned and centered.
skyhawk92
Post by skyhawk92 »
Just to hold it in place, I put microbaloon+epoxy in some places.
skyhawk92
Post by skyhawk92 »
Once hardened, I sealed the gap on the lower side, then poured in some thinner mix of microbaloon+epoxy and thicker one at the end.
skyhawk92
Post by skyhawk92 »
Roughly sanded in shape. Final touches will be done when wings are finished, just before painting.
Looking good...
skyhawk92
Post by skyhawk92 »
Corrected radius at the tail a bit.
