ο»Ώ
MU13 Charlesworth
MU13 Charlesworth
Post by John Vella »
I am well into the build now, thanks to the time saved with Cliff's laser cut short kit. The jig is window sill planking as a base. Being very solid it was turned round on the building table to work on each side when doing the "stick" work. The fuselage is out of the jig and nearly done. Sorry about the orientation as I am not building it inverted.πŸ˜€πŸ˜€
FrankS
Re: MU13 Charlesworth
Post by FrankS »
Very tidy, I had a 2nd hand one (it's now 3rd hand with a friend!), flew lovely.
Thanks for the encouragement Andy and Frank. I am sure the effort will be worth it . Here are some more photos with it out of the jig.
Regards John.
Now side skins and top nose complete. The gap between keel and sides filled as shown with 0.4 ply skin to follow to protect against arrivals on "outfield" landings. Very little weight for alot of work. I did similar on K8 and it's worth it.
0.8mm sides on, 5mm triang support gussets added.
0.8mm top skins fitted.
3mm balsa bottom infills
Sheeting completed to wheel box
Wheel box glasses in.
Fuselage skins finished, and floor between F1 and F2 glassed to reinforce the ballast compartment. A disc type nose release was fitted to the balsa nose block before bonding the block to F1. Weight of basic fuselage is just under 24 ozs.
Nose release bonded to nose block.
Glass reinforcement  of ballast area.
0.4mm  skins bonded underneath.
Nose block fitted.
Nose block fitted.
Post by roo Hawkins »
looking good john. may temp me to do some balsa bashing myself ???????? ROO :D
Geoff Pearce
Post by Geoff Pearce »
roo Hawkins wrote: ↑05 Mar 2018, 14:31 looking good john. may temp me to do some balsa bashing myself ???????? ROO :D
Roo, your far to young to go balsa bashing. It takes a whole different mindset :(
Hey Geoff steady on I think at 71 I am just getting into my stride as far as balsa bashing goes. It is most enjoyable when it is freezing outside to balsa bash in a really warm model room. It is also sound proof so I can't be disturbed by the "boss".😁😁
Geoff Pearce
John Vella wrote: ↑05 Mar 2018, 18:02 Hey Geoff steady on I think at 71 I am just getting into my stride as far as balsa bashing goes. It is most enjoyable when it is freezing outside to balsa bash in a really warm model room. It is also sound proof so I can't be disturbed by the "boss".😁😁
Hi John, I know what you mean, I'm also 71........The comment was meant for Roo....
Andy A wrote: ↑05 Mar 2018, 20:40 Looking Good Any ideas on colour and finnish yet?
Andy at the rate I build the decision of the colour scheme is some way off. What scheme is your MU13 ? Have you any photos ? Regards John.
