SZD - 36 Cobra 15 1:3 scale
skyhawk92
Post by skyhawk92 »
Same procedure for the other half.
skyhawk92
Post by skyhawk92 »
Ribs for elevator are made from 3 mm balsa, glued between and 5mm balsa used in the middle.
skyhawk92
Post by skyhawk92 »
Before I put it together, I checked how it fits.
skyhawk92
Post by skyhawk92 »
Ribs glued and carbon fibres added on the edges.
skyhawk92
Post by skyhawk92 »
Fixed everything same way as on wings and weighted everything.
skyhawk92
Post by skyhawk92 »
Edges sanded.
skyhawk92
Post by skyhawk92 »
Vertical reinforcement for tail, made out of plywood. Servo for elevator will be inside of this.
skyhawk92
Post by skyhawk92 »
Edge of the tail sanded to right shape and vertical reinforcement glued in place. A bit of glass fiber and epoxy is also added on the edge.
Looking good. Keep going....
:D :D :D :D
Martynk
Post by Martynk »
What is the box for that is attached to the rudder?
Superb craftsmanship by the way.
