Pat teakle asw 20 build
Post by roo Hawkins » 17 Jul 2018, 17:05
After seeing Brian sharps fantastic pt asw 20 fly at the mynd over the weekend I have started my build. The fuz is from cliff Evans and I am cutting the wings myself out of blue foam. started yesterday fitted spars today.
Re: Pat teakle asw 20 build
Post by Peter Balcombe » 17 Jul 2018, 17:30
What wing section are you using Roo?
Post by roo Hawkins » 17 Jul 2018, 20:17
The same has the original taken from the root and a tip template taken from Brian sharps at the weekend. Brian sharps few fantastically over the weekend so can not see that it needs changing. The span has been lengthened to 5 m though. Roo ☺
Post by Peter Balcombe » 17 Jul 2018, 20:23
Roo,
In that case, it is almost certainly a Ritz3 section as for the PT Vega.
Post by roo Hawkins » 18 Jul 2018, 15:27
Leading edge cut off and shear Web cut and will be glued in later today. When I cut the leading edge off one wing had a bad bow in the inside panel from the bow drag. So I cut a new panel and grafted it with the old outside panel. .so now all good.
Post by roo Hawkins » 20 Jul 2018, 16:10
All the spars fitted and glass tape applied. Now ready for veneer.
Post by roo Hawkins » 24 Jul 2018, 16:13
Panels veneered
Post by Barry_Cole » 24 Jul 2018, 19:36
Ready for the varnish then.
:roll: :roll: :roll: :roll:
Post by roo Hawkins » 26 Jul 2018, 17:10
Leading edge and trading edge glued on and shaped. Wings filled had to mix small amounts of filler has it was going off to fast in hot weather .
Post by roo Hawkins » 03 Dec 2018, 16:19
I have got back to doing the asw 20 after taking a break from it because I wanted to get two other fuselages glassed before the cold weather is here. As they are too big to fit in my hot box. I have glassed the wing tubes in the wings and fuz. I have also made up the joiner out of 14 mm steel rod glued inside a 16mm carbon tube.
