thanks chris
thought i was going nuts !!
will await the out come , thought was strange as rest of it all fits perfect
In the case of the MO2a, when the wing is locked into shape with the addition of the top sheeting, the two short lengths of TE either side of the flap are clamped to a straight edge whilst the glue dries...
The foregoing must be true, I have a hangar full of wings that say so!
thanks chris
just to get it correct, i should make the slots in the root ribs 1b wider so they fit onto the short
trailing edge at root , and the same for the 1c ribs ?
the ribs you show in pics are for the outer wing , not built that as yet
when i pin the spar on the plan the back of all r1 ribs are off the plan, which seems correct as the shape of ribs dictates this , if i cut the slots in 1b and 1c to fit to the short trailing edge , i will then have a gap at the top spar ( i can always fill this )
have tried again and still twists
just going to glue all up and try to get twists out later as just going round in circles
just looks like lots of washout on inner wing
Wing twist at this stage is irrelevant. It's not until the wing is on the jig supports and the top sheeting added that it all gets locked in place. As it stands at the moment you can twist the wing in any direction you like!
that’s one way of putting it Cliff
it will get there , just can’t seem to get it to work at the moment , so think will just leave it for a while - hope the balsa gods will sort it
thanks Chris
will do that , the spar won’t twist at the root
rib , as the joiner box is there and it’s solid
just concerned about lack of contact from the first 3 ribs at the root as wanted this to be strong and it seems i have to keep adding little bits in , it just doesn’t seem strong and it looks like i’m just bodging it up as i go along
but keep going
but keep going
Do 1 of 2 things........1 cut a whole new rib with the correct spar slots.....or 2 cut a partial rib and double up the area where the gaps are from making the existing rib “fit”.mick a wrote: ↑09 Oct 2018, 12:25 thanks Chris
but keep going
yea i think that’s what i will do
although already cut 4 new ones ,
just want to be sure all in correct place
with the root ribs etc as once all glued in
that’s it ,so just trying to figure out a
point to measure everything straight from
as every time so far (4 attempts ) it’s been wrong eithe trailing edge spar to high / too low
etc etc
hopefully will do
etc etc
hopefully will do
have tried 5th attempt at wing , still twisted , not sure what to do now ,as tried everything i can think of , i know a slight twist is ok
but i have a difference of 20 mm from root to outer rib , just on inner wing , if i glue (which i have tried ) , when twist back as though on jig it pulls the ribs or even break some
any advice would be great as just can’t get it
and can’t get on with anything else until done inner wings
think i have found the problem , just need a solution
as you can see from photos , the trailing edge of ribs will not fit on the trailing edge
if i put ribs to trailing edge as should be it sets a twist like a dogs hind leg
these pics are with the spars straight
any ideas would be a great help
main problem is that i have to use inner wings to set incedence with wing box
so just concerned if wings twisted -incedence will be wrong
