Hi all,just got an rb-10 redundancy bus..nice bit of kit,however,l was not too impressed to find that l will need to solder the leads from my two battery packs on to two VERY small solder pads,easy enough if you are a dab hand with a soldering iron,
:l would have thought Frsky could have fitted a plug on each side to plug into,my soldering is definitely of the agricultural variety,usually carried out with a screaming hot 100 watt iron
oh well,burnt fingers again
