thanks Chris
will make a note of that
does the main spar still taper from the wing join (12mm-6mm) or does that start from 13 as well ?
thanks again
mick
thanks again
mick
The main spars taper from the gull join, Mick...
cw
cw
a bit more done today
bit more done today
starting on the canopy , but seem to have gone wrong again !!!
the formers don’t seem to fit at all , 20mm short in width , has anyone got any ideas or methods how to get an even curve
to match front former
have tried to copy front and cut down - didn’t work
any ideas greatly appreciated
thanks mick
pics might help explain
thanks mick
Here are the all the frames for the canopies, Mick...check your parts against them?
- Attachments
- F6s F8b F8c.pdf
- (225.38 KiB) Downloaded 65 times
- FRAMES (1).pdf
- (239.48 KiB) Downloaded 47 times
- FRAMES (2).pdf
- (241.43 KiB) Downloaded 51 times
thanks Chris
will try that ,
will try that ,
Does anyone want a minimoa to finish off
have give up with it , just to difficult, seem to be having difficulty in every step
tailplane, rudder , inner wings and fuse all done
just canopy and outer wings to be finished
It has to be said Mick, the MO2a canopies are the most complicated canopies I've ever had to make (and then you have to paint them)...
hi Chris
i know what you mean, managed the front section and rear section - just a cannot get the middle to fit at all, either to small too big or wrong curve
it’s a lovely plane but just loosing the will to finish it ....
hopefully will get the enthusiasm back soon, as love to build but seem to be doing everything 3/4 times
OH the joys of modelling ..... lol
Can you post a pic of the part that doesn't fit next to the place it's supposed to fit?
