4.4 meter MDM fox
Geoff Pearce
Re: 4.4 meter MDM fox
Post by Geoff Pearce »
Yes
Post by roo Hawkins »
Glassed the outside of the Fox today.
terry white
Post by terry white »
Hi Roo, As I mentioned in our Facebook discussions, Why fly your plugs when with a little more work (at the rate that you work) you could make a mold from it then make as many as you wish. Then a disaster become just a mishap and you may also sell a few. ;)
So my suggestion for what its worth is to repair the fox fus to a plug value only. I.E. don't worry about added weight and make it strong to help its release from the mold. Use the rest of your saved time to make a quality mold.Then applying any alterations needed having learnt from the first model make a superb second and subsequent models.
Im sure Cliff Evens will put his name down for one maybe two. :roll:
Thanks terry for your suggestions. But I still do not know if I am rebuilding it yet. I am using some old epoxy up that I have. . I have outher gliders like my pt asw 20 and a 1/3 scale ash 31 to finish first. The Fox if I carry on will be done in between jobs. And when there spare time so not in a hurry to do.
Fuz is now repaired and painted
I pulled a new canopy this week and started the frame.
Canopy finished just now need a pair of wings.
Looks super Roo.
Good work Roo. I told you it was fixable! :)
Will it be ready for a maiden at Buckminster again. ;) ;)
Thanks guys. Hopefully it maybe done sometime at the end of the year. I have outher gliders to do first I am just doing bits on it when I have space between builds. I plan to start cutting the wings the same time as I cut the grob wings .
