mick a
Post by mick a »
a bit more done today
mick a
Post by mick a »
bit more done today
starting on the canopy , but seem to have gone wrong again !!!
the formers don’t seem to fit at all , 20mm short in width , has anyone got any ideas or methods how to get an even curve
to match front former
have tried to copy front and cut down - didn’t work
any ideas greatly appreciated
thanks mick
pics might help explain
Here are the all the frames for the canopies, Mick...check your parts against them?
F6s F8b F8c.pdf
(225.38 KiB) Downloaded 102 times
FRAMES (1).pdf
(239.48 KiB) Downloaded 78 times
FRAMES (2).pdf
(241.43 KiB) Downloaded 84 times
mick a
Post by mick a »
thanks Chris
will try that ,
mick a
Post by mick a »
Does anyone want a minimoa to finish off
have give up with it , just to difficult, seem to be having difficulty in every step
tailplane, rudder , inner wings and fuse all done
just canopy and outer wings to be finished
It has to be said Mick, the MO2a canopies are the most complicated canopies I've ever had to make (and then you have to paint them)...
mick a
Post by mick a »
hi Chris
i know what you mean, managed the front section and rear section - just a cannot get the middle to fit at all, either to small too big or wrong curve
it’s a lovely plane but just loosing the will to finish it ....
hopefully will get the enthusiasm back soon, as love to build but seem to be doing everything 3/4 times
OH the joys of modelling ..... lol
Can you post a pic of the part that doesn't fit next to the place it's supposed to fit?
mick a
Post by mick a »
hi Chris
here are the pics you asked for :
have nearly fished front cockpit no prob
any ideas would be great
thanks
mick
OK Mick...first of all, remember that there's a 3mm sq spruce rail that sits on top of the wing fairing, rebated 1mm to allow for the glazing.
Here's a screen shot with attached PDF of F7 & F7a, taken straight from the plan. Note the distance shown at the base of F7a: check to see if this matches up with your part? If it does, then for some reason the fuselage may be wider at that point that it should be?
mo2a.pdf
(256.67 KiB) Downloaded 65 times
