mick a
Post by mick a »
hi Chris
thanks for the pdf
the width of mine is 145mm , i have put the 3mm sq for the frame etc
the width of the top part of former on the plan and former itself is 125 mm
the last lot you sent i enlarged on photocopier to have correct width 145mm
but when i offered up it was the wrong curve
i think i will make one up in situ with .8 mm ply strips to get correct curve
it’s a strange one , it’s a challenge but will get there
Mick, what's the width of the fuselage at F7?
cw
mick a
Post by mick a »
hi Chris
it’s 145mm at f7
OK, the fog lifts a little...F6a is actually missing from the plan, so I don't know what the part you have labelled F6a actually is. Here is a PDF of F6a which I eventually found on my PC!
Cliff, can you add it to the plan file?
F6a.pdf
(223.11 KiB) Downloaded 74 times
mick a
Post by mick a »
thanks Chris
sorry to cause you headaches
that looks a lot better
No worries, Mick, best to get it sorted ;)
mick a
Post by mick a »
found this on the hungarian site, the club i belong to over there
does this look like the minimoa 2a to anyone else ?
Post by VinceC »
it is an Hungarian M-22 registration HA-4036. The dark bar on the bottom of the rudder gave it away as being Hungarian
Post by VinceC »
and more
mick a
Re: Minimoa MO2a -Chris Williams plan and Cliff Evans kit
Post by mick a »
wow thanks vince
