SF33 1/6 scale
Fans and Thermals.
Re: SF33 1/6 scale
Post by Cliff Evans » 14 Dec 2018, 07:44
Tony, you will need to order the canopy from Sarik Hobbies. https://www.sarikhobbies.com/product/sf33-canopy-ac11/
Tonyw51
Re: SF33 1/6 scale
Post by Tonyw51 » 14 Dec 2018, 21:34
Cheers Cliff. I'm onto that today.
Thanks and regards
Tony
Tonyw51
Re: SF33 1/6 scale
Post by Tonyw51 » 14 Dec 2018, 21:38
Thanks Peter, I must say that it was the Irish posting that sparked my initial interest in this model.
I look forward to asking for your assistance in the not too distant future.
Thanks and regards,
Tony
Chris V
Re: SF33 1/6 scale
Post by Chris V » 27 Dec 2018, 13:54
Hi there, I am really interested in building this lovely little motor glider
What electric set up is everybody going to use ie which motor and what power set up 3s or 4s lipo ???
Thanks Chris
Re: SF33 1/6 scale
Post by Peter Balcombe » 27 Dec 2018, 16:15
I have an old Dualsky XM3548CA-4 1080kv motor plus Dualsky XC4118BA 40A ESC which is expected to be used with a 9x6 or 10x6 folding prop.
Battery will be 2 or 3S to suit power required (I cannot remember at the moment what the Irish model setup was).
Tonyw51
Re: SF33 1/6 scale
Post by Tonyw51 » 09 Jan 2019, 02:39
G'day Peter & Chris,
Much excitement in the workshop today with the arrival of my short kit from SC Models. So now have the plans printed, mirrored and printed again (and they are a perfect match), the short kit and the canopy "in the mail" from Sarick. I am in the process of completing a Brolga (2.0 mtr. Australian model) and as soon as it has had its maiden flight I shall start on the SF-33.
I am very happy with the quality of laser cutting and I shall start to rifle though the stores of strip and sheet to put together a complete kit, so all is looking good
Re: SF33 1/6 scale
Post by Cliff Evans » 09 Jan 2019, 08:16
Glad you have it all sorted Tony.
Re: SF33 1/6 scale
Post by Peter Balcombe » 12 Jan 2019, 15:33
Spoiler now added together with servo & operation checked.
(Will need to be top wing surface hinged using film or tape in due course)
Aileron servo position added.
Spoiler + aileron servo
Spoiler servo
StephenB
Re: SF33 1/6 scale
Post by StephenB » 12 Jan 2019, 17:21
Very neat job on the spoiler installation Peter with the servo nicely hidden by the sheeting.
Having never done it before(always used commercial brakes), but about to tackle this job, how have you secured the servo and is the pushrod connection a z bend at both ends? Have you mde the spoiler from 1/16" sheet with ply reinforcement? The way you have done it looks a lot simpler than some methods I have seen which often employ a 6mm sq. balsa framework and a more complicated linkage arrangement.
Re: SF33 1/6 scale
Post by Peter Balcombe » 12 Jan 2019, 20:31
Stephen,
Servo body located in a slot in an extra 2mm Liteply sub-rib, with servo mounting lugs trapped behind balsa spaced off rib by thickness of lug. A touch of hot glue will firmly secure in place before bottom sheeting added later.
Yes, thin wire pushrod with Z bend each end. Needs to be exact length, but cannot come loose later when under sheeting.
Spoiler is 1/16” balsa with thin ply backing & 1/16” epoxy board horn glued in.
