Hi I was wondering if anyone could point me in the right direction for fitting an electric motor set up to a Chris Williams 5mt Flamingo.
We don't have any regular tugs available at our field so I would like to be able to self launch.
I already have a 6s set up on another model so would like to use a 6s set up on my Flamingo to utilise my batteries.
I anticipate the model to weigh around 10kgs and will launch from a dolly.
Cheers.
electric motor set up for Chris Williams Flamingo
Re: electric motor set up for Chris Williams Flamingo
Steve,
This is the motor that we are using, running on 6S. I fit a longer shaft. If you need more help PM me.
What motor Barry?
No info attached to your post !!!
Oooops...
https://hobbyking.com/en_us/turnigy-g60 ... -glow.html
Chris has used the 500Kv, but the 400Kv is the best one.
BC, whatever you do, don't tell John the latest use to which we have put this motor...this info is on a need-to-know basis, and he doesn't need to know
im using this one for the minimoa 2a it seems equivalent to the hacker motors
seems good value , although not as cheap as hk it’s from 4-max
Too late. He already knows. He will get better in time. I told him to rest in a dark room.chris williams wrote: ↑20 Jan 2019, 09:38 BC, whatever you do, don't tell John the latest use to which we have put this motor...this info is on a need-to-know basis, and he doesn't need to know
Thanks guys for the input, got some idea which way to go now.
I am still resting and in shock at the weight !!!Barry_Cole wrote: ↑20 Jan 2019, 13:15Too late. He already knows. He will get better in time. I told him to rest in a dark room.chris williams wrote: ↑20 Jan 2019, 09:38 BC, whatever you do, don't tell John the latest use to which we have put this motor...this info is on a need-to-know basis, and he doesn't need to know
