electric motor set up for Chris Williams Flamingo
Fans and Thermals.
steve white1
Post by steve white1 »
Hi I was wondering if anyone could point me in the right direction for fitting an electric motor set up to a Chris Williams 5mt Flamingo.
We don't have any regular tugs available at our field so I would like to be able to self launch.
I already have a 6s set up on another model so would like to use a 6s set up on my Flamingo to utilise my batteries.
I anticipate the model to weigh around 10kgs and will launch from a dolly.
Cheers.
Re: electric motor set up for Chris Williams Flamingo
Steve,
This is the motor that we are using, running on 6S. I fit a longer shaft. If you need more help PM me.
john greenfield
Post by john greenfield »
What motor Barry?
No info attached to your post !!!
Oooops...
https://hobbyking.com/en_us/turnigy-g60 ... -glow.html
Chris has used the 500Kv, but the 400Kv is the best one.
:roll: :roll: :roll: :roll:
BC, whatever you do, don't tell John the latest use to which we have put this motor...this info is on a need-to-know basis, and he doesn't need to know :D 8-)
mick a
Post by mick a »
im using this one for the minimoa 2a it seems equivalent to the hacker motors
seems good value , although not as cheap as hk
it’s from 4-max
chris williams wrote: 20 Jan 2019, 09:38 BC, whatever you do, don't tell John the latest use to which we have put this motor...this info is on a need-to-know basis, and he doesn't need to know :D 8-)
Too late. He already knows. He will get better in time. I told him to rest in a dark room.
steve white1
Thanks guys for the input, got some idea which way to go now.
john greenfield
Barry_Cole wrote: 20 Jan 2019, 13:15
I am still resting and in shock at the weight !!!
