All the instructions are in the photos on how to convert a wallpaper stripper to a wood strip steamer. You can add a proper blanking end to one end if you need to steam individual strips or as it is to slide along a construction in progress and steam a section of your strip. Block both ends with soft paper and start steaming.
Simple wood strip steamer
- VinceC
- Site Admin
- RobbieB
Re: Simple wood strip steamer
Clearly an avid Blue Peter fan.......................
Why??, Did they like paddling in the sea too??.RobbieB wrote:Clearly an avid Blue Peter fan.......................
- VinceC
- Site Admin
Just carried out my first two bends. Left them cooking for 15 minutes and they bent nicely.
Great minds .... Vince.
I used a similar method (without the neat wallpaper stripper pipe connector) when I needed to steam some stringers for my Olympia.
For others using this method, please note that the steam heat will cause a pipe of any length to sag if inclined at an angle and not supported much along its length. The sag will then set when the tube cools down.
