GREENLEY TUG BUILD THREAD 88"
Wayne Thompson
Re: GREENLEY TUG BUILD THREAD 88"
Post by Wayne Thompson » 28 Feb 2019, 18:45
.....and now the pics of the profile outline
Stuart Ward
Post by Stuart Ward » 28 Feb 2019, 20:38
That's the story, Wayne. Rough cut oversize and sand it with a long bar. Then ply the tip bays.
Stu
john greenfield
Post by john greenfield » 01 Mar 2019, 09:22
Wayne
I notice that you did not cut a 45 deg angle on the bottom spars, they seem to be cut flush with the end rib. A 45 deg angle on the bottom spars would give more support to the tip but you can cut some 45 deg triangles from 3/8 balsa and stick them to the ends of the bottom spars to do the same job.
Wayne Thompson
Post by Wayne Thompson » 04 Mar 2019, 20:20
yeah its a headache for sure plus i cut my fingers on the bandsaw same time so i took the easy route and sanded them flush and adding triangle 90/ 45 degree balsa to the space later then sand :-)
Post by Barry_Cole » 04 Mar 2019, 20:37
Ouch, and Yuk....
:cry: :cry: :cry: :cry:
Stuart Ward
Post by Stuart Ward » 05 Mar 2019, 07:42
Ohhhh( cringe) in the words of my grand daughter "hurt ' morning"
Stu
Wayne Thompson
Post by Wayne Thompson » 11 Mar 2019, 19:22
hi all
ok so this is where we are now..... see pics
got to glue in the webs then final sand and fit the tips and fill the spaces etc then ply sheet....
Wayne Thompson
Post by Wayne Thompson » 14 Mar 2019, 02:51
as usual distracted - too many things on my board so i made a tools holder along with the one i have . see pics
Wayne Thompson
Post by Wayne Thompson » 19 Mar 2019, 19:21
ok well got a few pictures for you......... how i finished sanding the tips, reinforcing and drilling the alignment pins , re-inforce the area for the tow release ( need to chat to Stu about that a bit more) thin servo area covers cut and now to make 3mm ply plates for each servo
Wayne Thompson
Post by Wayne Thompson » 19 Mar 2019, 19:23
and some more random pics . Thanks Stu for your build thread and motivation........ some good news finally got some $$ to buy a DG body for a 4.5m glider.
