Slingsby T.50 Skylark 4
Re: Slingsby T.50 Skylark 4
Post by Cliff Evans » 01 Mar 2019, 15:27
Another masterpiece Brian.
Post by B Sharp » 01 Mar 2019, 16:59
Thanks, but not so fast Cliff.
I had another look at the calculated C/G locations and was a little concerned that they were located a bit further aft than I expected. I checked the advertised location on the plan and that worked out at 25% of the root chord. (a bit too far forward for my liking) I then calculated the 15% static margin C/G position and that worked out at 39% of the root chord. (a bit too aft for my liking) I have now opted to go for a 33.3% root chord C/G position and work from there.
This is the second time that my C/G calculation softwear has given me a C/G location which is too far aft for reasonable stability. The last time was on my MU28 glider and that made for a very exciting first flight. I know I have flown gliders in the past with the C/G back at 40% - 43% root chord but these were competition thermal soarers which are a very different animal to a scale glider. Experience tells me that 33% is a safe starting point and I can work the C/G back (or forward) from there.
Brian. :x :oops: :cry: :roll:
Post by Cliff Evans » 01 Mar 2019, 17:13
You will be fine!
Andrew Ray
Post by Andrew Ray » 01 Mar 2019, 17:51
Crikey, I haven't been on here for a while and shocked to see I have missed the build, I need to go back to the beginning and catch up!
Beautiful job Brian, of one of my favourite gliders.
StephenB
Post by StephenB » 01 Mar 2019, 18:33
Looks lovely Brian, finish and build are immaculate. Looking forward to the update on her maiden.
What have you used for the pilot?
Post by B Sharp » 01 Mar 2019, 18:45
Thanks guys!
Stephen, the pilot is a Hobbyking 1/4 scale Piper Cub pilot. Scaled at 1/4 the full size pilot would be 5ft 2in, but scaled at 1/5 the full size pilot would be 6ft 2in tall. So this is a cheap pilot figure that works for many aircraft.
Post by Barry_Cole » 01 Mar 2019, 19:26
Brian,
Could you give us a link to that pilot, or the SKU number.
Thanks. BC
Post by B Sharp » 01 Mar 2019, 19:39
Sorry guys, that was a bit of misinformation. The company is Hanger 9 and the details are (J-3 Cub 1:4 Scale Full Body Posable Pilot
Brand: Hangar 9 Part Number: HAN4566 £14.09 Web Price.) It appears to be out of stock at present.
Further to the Skylark: it weighs in at 7lb 5oz (3.34kg) which give it a wing loading of 16.6 oz/ft2 Much easier to carry up the hill!
I will post further info once I have chucked it off a hill - however the forecast for the next week is a bit iffy up here.
Brian :)
Post by Barry_Cole » 01 Mar 2019, 20:41
Discontinued, B****r
:cry: :cry: :cry: :cry:
StephenB
Post by StephenB » 01 Mar 2019, 21:44
A canny buy that Brian :D
Meanwhile for the rest of us, the search for a sensible money pilot figure continues .................
