Mylar sheet thickness
MDev
Post by MDev » 17 Mar 2019, 10:08
What thickness is best for use in sealing control surface gaps on 1/3 scale?
Any favoured suppliers?
Re: Mylar sheet thickness
Post by Cliff Evans » 17 Mar 2019, 10:19
I usually use .8 to 1mm!
MDev
Post by MDev » 17 Mar 2019, 17:37
Plenty of lightweight Mylar around and places to buy but no 800-1000 micron Mylar, where do you purchase yours?
Post by Cliff Evans » 17 Mar 2019, 19:05
Ebay!
MDev
Post by MDev » 19 Mar 2019, 12:24
I've tried the model shops here and europe, ebay sells up to 350 micron but nowhere sells .8 to 1mm thick (800 to 1000 micron) that I can find.
Any other suggestions?
Post by Cliff Evans » 19 Mar 2019, 12:53
RH Nuttall in birmingham are going to give me a price, the more I buy the better price I can get! The do .8 up to whatever! You can approach them directly with your enquiry or wait to see what I can do!
https://www.rhnuttall.co.uk
MDev
Post by MDev » 19 Mar 2019, 16:26
Ok Cliff, Email when you have you have some.
:D
catwok
Post by catwok » 02 Apr 2019, 22:43
Look up Ideal Stencils on Amazon, the best thickness is 125 micron. 2m x 300 mm is about £12. It sounds very thin built when stuck on your wing with double sided tape it is stiff enough and flexible enough without straining your servo.
Post by Cliff Evans » 02 Apr 2019, 23:54
The sample I was sent was nothing like they described!
catwok
Post by catwok » 03 Apr 2019, 08:40
I ordered a sheet of 250 micron which is .25mm thinking it would be thin enough, but when it is attached to the wing it was putting quite a bit if strain on the servo. I now use 125 micron which is perfect. I can send you a,sample of each Cliff...
