WANTED the control surface gap covering tape. IE clear tape that is only adhesive on part of its with, to go over the gap of a top hinged control surface.
George.
07836581247
Control surface gap tape WANTED
Re: Control surface gap tape WANTED
never seen that type
what i do is slice 1 piece of tape to the width you don’t want sticking
and stick that to the tape sticky to sticky side, that way you have two sticking surfaces for
trailing edge and control surface
i use blenderm tape
hope that makes sense
mick
i use blenderm tape
mick
Diamond tape I've used this for years gooD stuff.
Keith
Keith
It's horrendously expensive, you can get it from lindinger
https://www.lindinger.at/en/airplanes/a ... 5lfm-clear
Plan hanging tape is very much the same if you can find it.
https://plan-tidy.com/products/a0-film- ... 7251598391
Ell.
Ell.
- terry white
George, Thin mylar strip fixed with double sided tape to the wing a little way back from the control gap to allow it to take on a slow bend on a down going aileron/flap. is the way to go.
I have a little to spare if you would like. Send me you're address and length requirement on PM and I will send it on return.
Regards Terry.
Regards Terry.
- jimbo
I heard you can use the stuff off the full size gliders, no idea where to get it from though.
- Antonia
Morning, here you go I've brought curved mylar tapes from them, no issues
https://www.gromotec.de/shop/?cat=c2_Sp ... ender.html
Hope it helps. Antonia
- Simon WS
Rather less expensive at Ripmax! £7 for 5m (caveat is I've never used it so don't know if it is any good!)
http://www.ripmax.com/Item.aspx?ItemID= ... ry=130-030
