HW-4 FLAMINGO 1/4 SCALE
Re: HW-4 FLAMINGO 1/4 SCALE
With the lower sheeting added in two sections, preparations are made before adding the top sheeting, which will be in three parts. The centre sheeting spans the gull break and is forced into a compound curve to preserve a smooth transition around the bend...
The most critical part of the wing construction: adding the top sheeting locks the wing into its final shape...
- Trevor
I'm not allowed to open up the wing root until Christmas...!
- Barry_Cole
- Trevor
Back to the fuselage now, and tidying up the lower fuselage...
Now for the tricky bit: setting up the wing root fairings...
