Hi All
I am just fitting out a Swift with a retract and am not sure of the best way to add something to retract the doors when the wheel retracts.
Any advice would be helpful. What system do you use etc.
Thanks
Barry
Retract Doors
Re: Retract Doors
You can power them with small servos. (Very complicated)
A small tension spring works well, as you can make it push the doors open wide to get more ground clearance.
It really depends on how much space you have, and the mechanics of the retract.
Maybe someone could post a few photos of what they have done.
Re: Retract Doors
I use 2 elastic bands one for each door.
Re: Retract Doors
Like Roo ,I use rubber bands to close the doors which pull the doors when u/c legs go horizontal. The same system as used full size substituting bungees for rubber bands. Regards John.
Re: Retract Doors
I use rubber bands too, sometimes actually connected to the retract arm so that the tension increases as it retracts.
Have now resorted to using silicone for the hinges, which works way better than anything else and is super resilient.
Ell.
Ell.
