norm
Post by norm »
I'd like to post my newest scratch build 1/3 scale Japanese vintage glider Mita type 3 mod1.
Above picture was taken at her first flight 19th Sept. 2019. I will post its details and how I made it during last 2 years. Please enjoy!
河上宣道
Post by VinceC »
Lovely glider and one I don't know anything about. Thanks for posting
Martin Gough
Post by Martin Gough »
Fantastic. Like that.
norm
Post by norm »
Cliff,VinceC and Martin, thank you for your comments.
Cliff, yes I also don't like the moustache. It does not fit her beautiful face but is necessary because I don't have a Tag nor a Winch.
河上宣道
norm
Post by norm »
About the Mita type 3 mod.1.
Believing that the Mita type 3 is not popular in the Europian glider community, let me introduce her.
The Mita type 3 mod.1 was designed by Mr. Asahi Miyahara in 1965 and took the first flight in 26th March, 1966.
It is two placed soarer used by many flying clubs and brought up many glider pilots in Japan.
General characteristics
1. Crew 2
2. Length 8.60m
3. Wing Span 16.0m
4. Height 1.3m
5. Wing Area 15.9m^2
6. Aspect Ratio 16.1
7. Airfoil NACA 633-618
8. Empty Weight 300Kg
9. Gross Weight 450Kg
10. Number of Production 32
Performance
Vne 180Km/h
Max glide ratio 30.8
Rate of sink 0.75m/sec
河上宣道
norm
Post by norm »
Cliff, yes I made the plan by myself using 2D CAD.
My 1/3 scale Mita type 3 has 5.33m wing span and the all-up weight is just around 10Kg. It has a fuselage made of epoxy bonded carbon pipes and covered with the SIG KOVERALL. The original Mita's fuselage is made of welded steel pipes and covered with cloth.
Because the 1/3 model craft's Reynolds Number is much lower than the original Mita, I changed the NACA 633-618 18% thickness airfoil to the NACA 632-615 airfoil which has 15% thickness. It was decided after the study of airfoil characteristics change at low Reynolds number by using the XFLR5 software.
fuselage structure
fuselage structure
河上宣道
Paul_Williams
Post by Paul_Williams »
Wonderful modelling of something not seen here before.
Will you post how you made the tube joints strong enough ?
Most impressed.
Paul
StephenB
Post by StephenB »
Beautifully engineered fuselage, quite an accomplishment - interested to see how you did this.
norm
Post by norm »
Cliff,
It is my pleasure and a great honor to donate the plan but the current plan is quite messy. After organizing it I will donate. Please wait.
Paul and Stephen B,
The fuselage structure was made of carbon tubes bonded by epoxy adhesive. After cutting the tubes, edges were trimmed carefully by a diamond file to fit well. The fuselage is composed from several truss panels. Each panel was built on a flat plate onto which the plan was placed. Attached is a shot of making a panel.
At this point, a bit of CA is dropped on each junction. After making necessary panels, then they were constructed. Second photo shows this process.
A bit of CA is dropped again. After the construction is completed, the epoxy adhesive is applied on each junction. The epoxy adhesive was mixed with a carbon powder.
The canted longerons were joined each other with a steel rod inserted inside with the epoxy adhesive.
assembling aft fuselage
making fuselage panel
河上宣道
Martin Gough
Stunning construction. More picture of the build would be greatly appreciated.
