SDZ-8 JAKOLSKA 1/3
Keith
SDZ-8 JAKOLSKA 1/3
Post by Keith »
Hi all, well got my new project from Cliff few days ago 1/3 scale Jakolska drawn by Jilles, second set of drawings I have had from Jilles, really detailed. Cliff has done a fantastic job of cutting the kit out so clean and crisp. Plus has supplied flap tracks, and nose cone 3D printed.
I'll keep you updated on the build as best I can, not going to be a quick build but I'll do my best.
Elliot Howells
Re: SDZ-8 JAKOLSKA 1/3
Post by Elliot Howells »
Great stuff! keep photos coming Keith ;)
Dopieman1
Post by Dopieman1 »
The Jaskolka is one of my favorites! Ik will follow. Thanks for sharing.
Keith
Post by Keith »
Ok more building been taking place, thanks to Cliff I can now put more pictures up.
Tailplane bearing and attachment assy
Main plane joiner assy
Wing blade tubes x2 each side
Post by roo Hawkins »
Lovely glider I have John watkins jaskolka the original one he built.will be following.
Post by John Vella »
roo Hawkins wrote:
06 Feb 2020, 18:14
Roo, I remember that glider very well and as you say a lovely glider posed at my old stomping ground Ivinghoe unless I am mistaken. Regards John.
jack
Post by jack »
So nice its a shame to cover it :lol: :lol: :lol: ,good job,good luck with the build,jack :) :) :)
Keith
Post by Keith »
Ok some work carried out to fuse, main wing incedance doubler glued in, canopy/cockpit shelf attached sorry about the weights there just to keep everything flat, I'm enjoying the build chamfering the joints takes time. Secured the fin vertical hope to get the logerons in tomorrow. Just recieved the canopy nice moulding from Sarak.
Keith
Post by Keith »
A little more work done, stringers attached and cockpit sill added, rudder started, and rear incidence doubler fitted, sorry I cant make this exciting but if you built a large model some things go together quickly some need a little fetling, on the whole it is going together well. Stay tuned ;) ;)
Dopieman1
Post by Dopieman1 »
Keith wrote:
10 Feb 2020, 19:42
Good to hear about the availability of a canopy! Saves a lot of work making a plug! If I wasn't so busy with an Ikarus Meteor I would have joined you in building a Jaskolka ;)
