BJ-1 DUSTER**
Re: BJ-1 DUSTER
If you're short of space, then the 7th scale Wolf might be the answer...?
Re: BJ-1 DUSTER
Chris, thanks. Thats a good thought. Im am also just looking in to making that little bit extra room for a Petrel.....
Re: BJ-1 DUSTER
Hi all
I've just purchased the the plans and short kit. Looking at the plans, am I right in thinking that the coupling between the centre wing section to the outer wings is friction based using piano wire and brass tubing?
Regards
Mark
Regards
Mark
- Cliff Evans
Re: BJ-1 DUSTER
What most would do is put the wing together and then a strip of tape over the joint. There are so many different methods for holding wings together. I am sure that members will offer their own views on this subject.
Re: BJ-1 DUSTER
Yes, at this scale, tape is the ideal solution. However, when I did the same thing on the 3.5 scale version, the tape was too strong, and catching an obstacle on its first landing, the centre section was written off as there was no give in the system. This goes to show that the principle of flexibility in a wing retention system is important!
Re: BJ-1 DUSTER
Mark, let me have your email,address and I'll send you all the construction pics
Re: BJ-1 DUSTER
It's the thought that counts...
