Hi all,
How and what do you use to check C of G on large scale models?
Thanks,
Phill
C of G measuring
- RobbieB
Re: C of G measuring
A simple balance Phil with a graduated scale which indicates the position of the CG behind the leading edge. Very sensitive and more than accurate enough.
Doesn't take long to put together and you only have to make it once.
There is a 'hanging from the ceiling harness and plumb line' method but I found that a bit of a faff.
- Max Wright
[There is a 'hanging from the ceiling harness and plumb line' method but I found that a bit of a faff.
[/quote]
It's called a Vanessa rig, Robbie. It's good for heavy warbirds et. al.
[/quote]
Max
Thanks chaps,
I will have a go at making both, although the engineer in me wants to have a go at making something using load cells like this http://mahmoudi-modellsport.eu/glidercg-15kg
Phill
Phill
- terry white
Phill, spend your time and money on the model and build the one shown by Robbie. Most of us have one and it does us proud.
Phil,
T9HobbySport do the 4Kg & 8Kg Max. units for approx. £103 each.
I built a similar function load cell type unit a few years ago & use it for smaller models.
My main concern with the electronic units is that all of the model weight is taken on 2 relatively small pads under each wing - the pads need to be small to measure loads at defined distances from a reference point for the overall CoG calc.
Robbie’s unit looks simple to make & easy to use - just doesn’t measure AUW at the same time.
Peter.
Peter.
- RobbieB
Yep, saw one on here (Brian's I think) and just built it - so easy and cheap, less than a tenner plus some scrap if I recall.terry white wrote: ↑03 Sep 2020, 11:06 Phill, spend your time and money on the model and build the one shown by Robbie. Most of us have one and it does us proud.
- Noël Rumers
Hi Phill,
I did see this one with a rather big plane on...
I build it and works fine.
Noël
Noël
MPX balancing rig - about £20 when I bought mine decades ago and it will handle up to 16kg because I did my Let Ash 26 on it for the maiden.
About £40 now, or pence if you copy Robbie's in scrap wood.
John M
John M
