Falke T-61A Cliff Charlesworth Plans.**
Max Wright
Post by Max Wright »
There is only the right wing plan in the kit, so I took mine to Officeworks and had them scan and flip the page with the wing on it.
Placed against the original, there is only a millimetre in it.
Some of the guys on RCSB are reporting plan sets with both wings drawn and the wings being 15 mm different lengths!
I couldn't be happier with the result. 8-)
Max
Max Wright
B Sharp wrote: 27 Dec 2020, 08:50 That's coming along nicely Max. There is no need to forget your progress, just use your photos from this build thread.
Ha ha! Thanks, Brian. :lol:
Max
Trevor
Post by Trevor »
Great to see this coming on well Max, especially after all the angst at the start!
Max Wright
Thanks, Trevor.
I have your site on speed dial. 8-)
Max
Bovin
Post by Bovin »
It looks very well :). And a very nice building table!
Vincent.
Max Wright
Thanks, Vincent. 8-)
Max
Max Wright
The left wing is coming along.
The second one is easier - not so much thinking time involved.
Max
Trevor
Post by Trevor »
Max Wright wrote: 03 Jan 2021, 06:52
Beware! The chances of going wrong are also much higher on the second one - for the same reason!
Trevor wrote: 03 Jan 2021, 09:11
Yes, been there, done that.....
Max Wright
OK. I've assembled the second wing to the point where I can attach it to the bit of the fuselage that I have built up.
I figured that I should see if there are any issues which need my attention while I can still make adjustments.
It all fits pretty well, except for where the back of the right wing meets the fuselage rib. There is a bit of a gap, but I can glue on some more balsa and sand it back until it's fair. A simple job.
I went back and had a look at the photo shoot I did on the prototype and I must say - it all looks pretty good.
The sweep of the wings and the dihedral look very convincing - as do the cranks.
Now I can complete the covering, ailerons and spoilers and make the wing bags for protection. :?
Max
