Followed by the AMT...
DART 17r QUARTER SCALE**
Re: DART 17r QUARTER SCALE
Now the rear end can be brought nearer to a conclusion...
Moving on now to the canopy frame...
Now for the wings...The Dart has two brass joiner boxes in the wing, one 16mm & one 13mm: each one sits under one set of the 5mm spars. It's always a good idea when epoxying in the second joiner to insert the blades and check that they are absolutely parallel...
- Andrew Ray
Hi Chris, is the ply sheeting on the rear fuselage 1/64 or 1/32? I ask as I would have assumed 1/32 but it looks more like 1/64 to me from the colour in the photos.
No Andrew, that's 0.6mm, or 1/48th ply...
- Andrew Ray
Ok, thanks, .6mm is a size I hadn't come across. I'm enjoying seeing this come together.
- Cliff Evans
You can get 0.6 from SlecUK.
With the lower sheeting added, the wing can be laid on its jigging supports and the top sheeting glued in place....
- Andrew Ray
Thanks Cliff, I've just had a delivery from SLEC too!
