ASK13 1/3 Scale**
Re: ASK13 1/3 Scale
I am only limited by the size of the printing bed, what scale do you require?
catwok
Re: ASK13 1/3 Scale
Post by catwok »
33% and 40% if possible :D
Re: ASK13 1/3 Scale
Picture of the previously featured full size tailskid parts re-assembled back onto the glider after refurbishment.
Re: ASK13 1/3 Scale
With a bit of sunny weather upon us & the 2nd wing structure now at the same build state as the 1st, it’s time for a trial assembly ;)
Next job is to prepare the balsa spar caps & False LE for applying the top skin.
Re: ASK13 1/3 Scale
Brian will be after you about that grass!!! :shock: :shock: :shock: :shock:
Re: ASK13 1/3 Scale
Barry_Cole wrote: 26 Feb 2021, 14:34 Brian will be after you about that grass!!! :shock: :shock: :shock: :shock:
You should have seen it before I cut it :lol: :lol:
Max Wright
Re: ASK13 1/3 Scale
Post by Max Wright »
It's a beautiful thing, Peter.
Almost a shame to cover all that lovely work. 8-)
Max
Re: ASK13 1/3 Scale
The grass is Ok Peter. Keep the cut hight high for the first cut, a quick scarrify and a spring feed to finish!
The aeroplane is not looking too shabby either.
Brian. :D
Re: ASK13 1/3 Scale
A metal bashing day today ;)
All horns, wing retainer clips, brass tailwheel support plates plus first of the main wheel support plates made, so just the 2nd mainwheel plate & front wheel plate (as indicated by the paper templates) left to do tomorrow.
(The tailwheel plates are my design & I decided to use 1mm Brass rather than Aluminium in order to get strength from thinner plate as these will be attached to outside of the wheel box framework as per the full size. With 0.6mm ply fuselage skins, only the very bottom parts should be visible. (On the full size, the wheel brackets are welded to the outside of the tubular framework which is fabric covered as shown below).
Re: ASK13 1/3 Scale
All 3 wheel axle supports now fitted & wheels checked for fit.
The nose wheel is a 3.5” Dubro mounted on a 4mm axle, the mainwheel is a 110mm FEMA mounted on a 6mm axle & the tailwheel is 67mm, mounted using a M3 hex headed bolt.
The tailwheel brackets are sandwiched between the 1/8” ply plates visible in the photo & the 0.8mm external skin yet to be fitted.
Front wheel
Front wheel
Main wheel
Main wheel
Tail wheel
Tail wheel
