Pat Teakle Asw 22 6m**
Re: Pat Teakle Asw 22 6m
Thanks for the suggestions chaps. Here are more progress shots of the tail feathers, rough sanded. will finalise servo installation tomorrow,then glass .
I decided on the servo below,8 kilo pull at 4.8v.Should be fine.
Have a fab weekend gentlemen.
Where are you planning to put the servo Dave?
In the fin, or will it fit in the tailplane?
Hi Peter, In the fin with an 80mm x m3 pushrod and metal clevis. Threaded both ends with lock nuts.
Dave Mackintosh wrote: ↑13 Mar 2021, 18:18 Hi Peter, In the fin with an 80mm x m3 pushrod and metal clevis. Threaded both ends with lock nuts.
Thanks Roo.
- Andrew Ray
Ah, yes. I don't think I'd try a standard servo in the finDave Mackintosh wrote: ↑13 Mar 2021, 18:18 Hi Peter, In the fin with an 80mm x m3 pushrod and metal clevis. Threaded both ends with lock nuts.
Nice job, tidy workshop too.
Thanks Andrew.Andrew Ray wrote: ↑15 Mar 2021, 19:54Ah, yes. I don't think I'd try a standard servo in the finDave Mackintosh wrote: ↑13 Mar 2021, 18:18 Hi Peter, In the fin with an 80mm x m3 pushrod and metal clevis. Threaded both ends with lock nuts.
Hi folks.
I cnc cut the inner panels tonight, allowing for skin and carbon cuff thickness. I will cut the mid panels tomorrow and sand and prep the inners.
- Cliff Evans
Looks good Dave.
Thanks Cliff.
