Slingby Kirby Kite 1:3 Jilles**
Hi All. slowly the build on my scale 1:3 Kirby Kite has started. In this design the wing to fuselage and wing struts connections are close to scale
Each wing has three pins to the fuselage top with the wing struts keeping the wing at the correct angle. The means there are a lot of metal parts involved . The majority is 0.8mm (0.032") brass sheet. That requires a lot of cutting and drilling. To save time and increase the accuracy by a lot I investigated if I could have them Water Jet cut. Wate rJet cutting has the advantage over laser cutting that there is no heat involved that would deform the parts in the process. I found a local outlet that was prepared to do this relative small job. The cutting fee was AUS$88.00 roughly GBP45.00 in todays rates. I had to supply the material. 3 brass sheets of 10"x4"x.032" were required from K&S. The parts need to be nested with a greater distance between them than with laser cutting so a bit more waste. In my case they could only cut minimal 3mm holes. Most holes are 2.5mm and they were only pierced in the center at 1.2mm diameter. In my view this investment is worth the effort. It saves time and you get more accurate parts as well.
This does not mean you cannot make them by hand as long as you have the time and tools. The parts are left with little bridges in the nesting, see picture BRASS1. A couple of larger parts fell out anyway.
I made a start with preparing the parts for later fitting in the model.
First I drilled the pierced holes to 2.5mm. I used a piece of timber and in my drill press drilled holes to suit the various tubes sizes that need to go through these brass items.
Similar items were stacked together with the matching tube as guide
drilled the first 2.5mm hole and fitted a M2.5mm bolt, then drilled all the other 2.5mm holes
All done in the drill press so they are all plumb. see picture BRASS2.
The bottom bracket in the fuse for the wing strut connection has a doubler and tube ( say Boss) soldered to it.
Again a piece of timber was used to have two brackets lined up and the tubes square and parallel.
I used hard solder (No resin) and flux. With a little gas burner it was all heated up and soldered. see BRASS3
Separated the parts and trimmed the tubes to length. Smooth on one side, 1mm high the other side. parts cleaned of residue flux with water and a steel brush. then drilled the outer 2.5mm holes through the bracket and doubler plate. Piece of cake so to speak, see BRASS4
The little gas burner I got from my local hardware store for $8.00. It can be refilled but that cost probably more than buying a new one
There is more soldering work to do on other brass parts that will be performed in the same way.
Picture kb13 shows the original fuselage bracket to take the wing strutsat the bottom. Left and right are separate items. I decided for structural reasons to make them in one piece but kept the original shape were they are visible.
A model friend of mine Brian Ford invested in a large Laser cutter. and he is prepared to cut all the laser parts for me. This is for Brian a first to cut a large kit so a learning curve for him and I will not pushing him. Next post will be when the laser parts are in house.
This build is not going fast. There is a short supply of spar and stringer sections and shops will not restock until April or so. I have them now made for me and have them I hope in 2 weeks. NC cut parts are also on the waiting list
In the mean time I worked on items I could proceed on, The Skid assembly is one of them
Made a template with the correct curve . 4 layers of 1.5mm ply strips were glued together on this curved template. The sides then trimmed to the final shape. Not sure if the original had them but I decided to fit metal wear strips to the underside of the skid. Gliders in the 1950 with a timber skid had these strips and with the not so smooth field I normally fly from in mind they would not be an overkill.
It required 6x1mm aluminum strips. I could only get 25x1mm so I made a make shift router with my Dremel and cut them with a cutting wheel
Just a small cut every time. It took around 20 strokes over the strip length to cut through and went through 3 disks per strip in the process.
There are no doubt better tools to do this but I used what I have at hand and it worked. Plenty of time anyway
The strip are test fitted with small nails at the moment but I try to get small screws for final fitting
The receiver bracket for the main rubber block was hand made and fitted in place. it will be painted later. The rubber block is in my case a 3D printed parts from high strength ABS. and painted black, nobody will know it is not rubber. You can 3D print with a rubber type of material but it will not have much strength. It will take all the landing forces so it need to be strong, not to mention the occasional harder than normal landing we all have and side loads in cross wind
When not building in the workshop I am working on a design for a rather large scale glider for a local customer. more on this in the near future.
- Cliff Evans
The good thing about printing with TPU Rubber filament is that you can adjust the print fill and make the mount as herd or soft as you wish. About 75% infill makes the mount hard enough for an affective rubber mount. I use a filament called "nijaflex" for this type of job.
received the NC laser parts last weekend, so no excuses and start building. We are in a mini lock down so not much else to do
Started on the tail bits. rudder and Horz. stab.
Beautiful glider to model!
Its on my todo-list as well.
Follow with great interest!
Rudder completed, all up 105 gr. Planking of the horz.stab. in progress. All0.4mm plywood. the LE is a wrap around bit. made a cardboard template, this saves plywood in the end.
Fuselage formers were set in place. Most of my design have building stands/tabs on the formers. With these tabs there is no need for a jig.
Only the occasional bracing until the stringers and and some planking has been added.
The wing is connected to the fuse with three pine like the original. jig pins were used to make sure the three pin align and also the spacing was checked. With NC laser cut parts this is more just a check than the need to get it in the right place. the parts fall in place at the correct location or distances anyway.
fuselage is ready for planking, but decided to get the canopy frame don first. I will build the production canopy with wind screen. Got a 1:3 pilot that fits the open cockpit era. the shoulders are a bit wide and will get some surgery later. Assembled and planked the seat and parachute box. These are not essential items but will hide the servo's and receiver later for those that want a scale like cockpit. The instrument panel is 3D printed. This is a two part setup. a black rear panel with instruments rime and or body. the front panel fits over the rear panel and can be painted in the required color. Instrument front to be added. To suit the vintage glider a Cosmin vario is used.
In the front plateaus were added the hold the final trimming balance weight and Lipo battery.
Fuselage planking is now underway/ Starting at the top from tail to front. the plan is the have a clear varnished finish. This is a challenge. the nose has a strong compound curved surface. At the top 6 mm balsa segments were fitted between formers and stringers to support and get a grip for the ply strips. On attached picture of the original the strip pattern is shown. It is essential that no glue will be on the exposed surface, this will shown when varnished, I will cover this surface with 3M invisible tape when glue is applied.. The ply patch on the nose cone is a tryout how to stick the ply to the ABS nose cone. This is glued on with Acetone. Not sure if this will give a good permanent result, I will tell you later
If somebody has experience, do I have to pre form the ply and how is that done ?
- Bovin
Hi Jilles,
I made similar nose cones? with varnished ply on my Slingsby Gull and my present Slingsby King Kite (my building reports are on this site). Hopefully you can find some ideas in them.
If you doubt the glueiing to ABS ( I have only try & error experience with glues) maybe you can use the ABS cone as a mold to make an glass/epoxy cone.
I simply made a balsa nose cone from 20mm balsa planks? glued together cut and sanded in shape.
Vincent.
Vincent.
thank you for the suggestion. I stick with the ABS cone, A glassed cone would have the same issue I think..
One of my fellow club members offered me to try a special epoxy to try out
will report on this one at a later date
I still want to have a clear varnished ply surface like the original ones. There seems to have existed a red Kirby Kite with closed canopy, that is no option for me see attached picture
Jilles
Jilles
