Hello
I am looking for some one who can undertake to digitize (from picture/pdf and supplied dimensions) and cut sheet metal parts in brass and some Aluminum alloys.
I will cover the agreed costs. Parts will need shipped to India.
Do respond if some one is willing to discuss this further
Best regards
Manish
Looking for some one to digitize and cut metal parts
- Cliff Evans
Re: Looking for some one to digitize and cut metal parts
I or Jilles can supply you with the digitised parts, but they are, apart from one part too small to cut with a laser machine and most laser machines will not cut brass or aluminium Jilles may know someone in Australia that could do it for you, whoever does it, it is still going to cost quite a bit to have it done and posted to India whether it is done in UK or Australia. You are probably better off doing it all by hand which is what most modellers would do.
Cliff
Thanks for offer to help. I will get back in case I need your or Jilles help. I have found some one local who is working on it .
Thank you once again
Cliff, happy to state that I have started construction of the 1/6 T 21 B kit. The metal parts that I was looking for earlier are all done and in hand. Got delayed due Covid and I did not want to start the kit unless I had the metal parts in hand.
I am once again looking for help
1. What should be the projected/target weight of the completed model ready to fly?
2. How does the Elevator leading edge, ES1, the central doubler ES2 and the Elevator horn assemble. The doubler ES2 clearly goes on the rear face of the elevator leading edge ES1 , but I am unable to decipher which side the central slot faces? Open end up or down and how does the brass elevator horn assemble between the ES1 and ES2. Picture of the parts is attached
[Any help will be appreciated
You do not have the required permissions to view the files attached to this post.
- Cliff Evans
Glad to hear youbhave the metalwork sorted. The person to ask re assembly would be Jilles, you can pm him here: ucp.php?i=pm&mode=compose&u=344
